I have just replaced two light fittings with two fittings each with 4 50watt halogen bulbs. These are connected to the same double light switch (not dimmer)as the previous fitting. Switch is a double switch from B&Q and reads 6Ax250VOLT on the back of each switch. Sometimes the lights work but twice, one of the switches has blown. I have checked the light fittings and wiring with a meter, no short circuits and everything reads as it should. Wiring is normal lighting wire but this is connected to a ring main rather than the house lighting circuit. No problem with the previous fittings. Any suggestions where I go from here?
