Have a possible job to wire up a boat, anyone know of any good guides to this sort of work??
i think you mean DIVING dont you :innocent Wet Fish:coat:^O:^OBoats are exempt from building regs, so as far as I know you can do pretty much whatever you like!At least driving an earth rod in should be easy enough...
:innocent
You are thinking of a floating earth... :coati think you mean DIVING dont you :innocent Wet Fish:coat:^O:^O
think it will be more houseboat than yacht - I haven't actually seen it yet, but want to go in a bit prepared in case owner asks awkward questionsIt won't need building regs, but should still comply with wiring regs.Treat it like a caravan installation, i.e use flex because of possible vibration rather than single core etc. If it's a steel boat, bond hull to CPC.
Will it have mains hookup, or a generator off the engine? or is it a static houseboat?
Not for Roman Abramavitch thenthink it will be more houseboat than yacht - I haven't actually seen it yet, but want to go in a bit prepared in case owner asks awkward questions
So do I, might be able to take up fishing whilst I'm at it :^OJust a few sites i foundgoogle narrowboat electrics etc
http://www.narrowboatbuilding.com/narrowboat-electrics.htm
http://www.leisure-electrics.co.uk/faqs.htm
i quite fancy getting into this kind of stuff
