Southcoast2015
HI Guys,
New member here.
I've had a look round on here a few times, and now I have a question that you may be able to help wit.
Doing some work for a customer and I noticed that the main incoming gas pipe is bonded as it enters right alongside electrical supply.
The water on the other hand isn't bonded, I've had a look and it enters in the corner of a dining room, it's boxed in (stopcock can be accessed through small door in the boxing in)
It rises up about 6ft to a plastic speedfit connector so the rest of the pipework is insulated from the incoming pipe. The nearest socket is the other side of the room, so you couldn't ever really touch anything that may become live and this pipework at the same time, unless you were knelt on the floor with your hand inside stopcock access hole and had something on extension lead in your other hand???
I've did long lead test between pipe and MET and there's 1 Ohm there, Given that this ready is fairly low for something that isn't bonding and the fact that know one could ever touch it and something live - Would you guys bond this?? The run would mean floorboards up in 2 rooms upstairs, potentially tiled bathroom floor too and maybe a section of ceiling in the dining room to get the 10mm over to pipe.
Thanks in advance
New member here.
Thanks in advance
