avinalarf
- Jun 2, 2008
- 415
- 0
If you're not interested in what people on this forum have to say - save your obviously valuable time and don't bother reading the threads!:z :z:z:z
GH - the bonding in question is for the main water. Should I insist they get cupboards removed or cut an access hole then?You are correct and those main bondings always have to be available for inspection and testing.My answer above was for supplementary bonding which continuity could be checked by testing and if soldered does not need to be available for inspection or testing. It is more cosmetic for bathrooms in that the horrible green and yellow cable does not need to be on show.
Ok, I'll speak to them. Forgive my ignorance, but what's a "Fein"? :|Even for a minor change you need to confirm water (and gas etc...) is bonded correctly to 17th and I am not sure you can confirm that at this time so I guess you may need to.Have you got a Fein or similar as you should be able to cut out a neat hole and put the bit back in after without too much drama.
Ian.
well you obviously dont know much.What you on!!!!!!!!!soldered to pipe work never heard such BS i think you had better stop adding this post andyc:z:z:z:z
Sorry for replying a tad late the others have answered I think but just to clarify, yes you are correct the main bonding to the water should be available for inspection.GH - the bonding in question is for the main water. Should I insist they get cupboards removed or cut an access hole then?
he uses all those tools on the cowsJeez Apache! Are you REALLY a vet? You're so resourceful. Thank you. :x
Blimey! Looks like one would need to go on a course to learn how to use it Applaud SmileyOnly the most useful tool you will ever get. There are some cheaper copies but they do not include all the bits. Have a look at this video:
https://www.youtube.com/embed/nynD2SfyINU?feature=oembed
