- Feb 12, 2008
- 1,653
- -1
If you have too many master sockets, the phone won't ring. It's all about Ringer Equivalence Numbers (REN). Most telephone handsets have a REN of 1, some old fax machines are 1.5 or even 2. BT guarantee a REN of 4, meaning you can have 4 phones plugged in and they'll all ring. Each master socket is REN1. So if you have 4 master sockets, you can have 0 phones ringing.
When wiring them up, connect BLUE/white to 2, WHITE/blue to 5, ORANGE/white to 3, and WHITE/orange to 4. 4 isn't actually used, but it should be connected to balance the cable, or you may find you have problems with broadband, particularly if you live a long way from the exchange.
Although the line only uses 2 and 5, and 3 for the ringer, 4 must be connected to balance the cable. It's best to connect all six wires to be certain of no conflicts.
Colours (for cable post 1985ish)
1 = GREEN/white ring
2 = BLUE/white ring
3 = ORANGE/white ring
4 = WHITE/orange ring
5 = WHITE/blue ring
6 = WHITE/green ring
Older cables
2 = Blue.
3 = Green.
4 = Brown.
5 = Orange.
Fault Finding
No ringing -
Terminal 3 disconnected
Phone ringing continuously -
Terminals 2 and 5 swapped (2 at one socket connected to 5 on another and vice versa)
Very poor speech quality, possibly poor bell. -
Terminal 3 and 2 or 3 and 5 transposed
Ringing but no speech (or very poor speech) and can't dial out. -
Wire between terminals 2 or 5 broken.
BT Dropwire comes with 2 pairs of cores.
Pair 1 is WHITE & ORANGE
Pair 2 is BLACK & GREEN
Only 1 pair is used for a single phone line and this is usually Pair 1, but not always!
Pair 1
WHITE = White/Blue Bands = Terminal 5
ORANGE = Blue/White Bands = Terminal 2
Pair 2
BLACK = White/Orange Bands = Terminal 4
GREEN = Orange/White Bands = Terminal 3
BT line voltage is -48v DC wrt earth across pins 2 and 5, supplied at 40mA. Ringing voltage is 70v RMS AC superimposed on the DC line.
2 = BLUE/white ring
5 = WHITE/blue ring
Older cables
2 = Blue.
3 = Green.
4 = Brown.
5 = Orange.
Fault Finding
No ringing -
Pair 1
Pair 2
