bt extention problems
adonoghue1985
Jan 12, 2011
29
Hi all,
I've recently added 2 slave telephone points from a by master point. I've checked my connections and the cables correspond with each other but I'm only getting a a dialling tone from the master socket and 1 of the 2 extensions. Can anyone give any ideas as to how I can remedy this?
Many thanks
either wired wrong or you have a duff connection at one of the 2 slaves OR where it connects to the master
Are they IDC connections or screws?
If IDC how did you crimp/dimp them?
Redo your connections and try again
What is the REN total of all items plugged in?
REN number is on the label on the equipment, max allowable is 4
............................. :coat
---------- Post Auto-Merged at 17:49 ---------- Previous post was made at 17:47 ----------
did you use cw1308 BT cable [solid cores] or burglar alarm cable [quite common but F wrong]
Thanks everyone for the replies. Turns out it was a faulty connection at the end slave.
