Beat me to it as i was being more erudite. .............now that WAS a good epoxy glue!Canoeboy said:Vernier Caliper and Calculator
10 t -6 is its accuracy not its limit. depending on the size of the micrometer
what is your point..........25.000004mm is more accurate than 25mm it is not limited to just reading micro readings :yawn(µ) or 10−6
(µ) Is the Si symbol for Micro 10−6 is the scientific notation for 1 millionth each are the same value expressed in different ways.
Im confused now,Which is not the size of the cable with insulation and sheaf is it?
This is a much duller debate than the homes under the hammer thread but it seems to keep going. opcorn
Why half it?vernier caliper or more accurate, a micrometer The answer is diameter so half it to get the radius then it is
Pi x r2
and get your slide rule out..... :innocentWhy half it?
Just use (Pi x D^2)/4!
My slide rule does the area calculation on the cursor.and get your slide rule out..... :innocent
So does mine.....British Thornton i think, buried in the loft along with the LPs and Singles, and Amstrad PCWsMy slide rule does the area calculation on the cursor.
Just like kW to HP and back.
