R
Raven
Guest
Hi, I am new to the forum, i would be greatful for help on the questions below. (including workings out).
1> Calculate the inductive reactance of a coil with inductance of 0.1H connected to a 50Hz supply.
2> An inductive load with 10ohms inductive reactance is connected to a 100V 50Hz AC supply. Calculate the power dissipated in the circuit (ignoring any conductor resistances).
3> The current in a coil changes from 5 Amperes to 2 Amperes in 50mS and induces a voltage of 30V into the coil. Calculate the valur of inductance in the coil.
4> Calculate the synchronous speed of the rotating magnetic field in a 4 pole synchronous motor.
5> R1=5ohms R2=10ohms 20V Supply.
Based on the above, calculate the power dissipated by the resistor 2 in the circuit.
describe what synchronus is?
