can i do this
yellowgold1
Apr 3, 2018
5
hello,
I just wondered if anyone can please help.
I have a range cooker that needs to be hardwired in to the wall.
I wonder if I can just wire it straight in myself and then plug the other plug into the above worktop socket.
my wall has the electric thingy on the wall about a foot below cooker level and then it has the electric socket with a switch on the wall just above the worktop. thank you
how do I find the oven rating please? my book says twin ovens 5200 watts..is that it? thank you
it says  this appliance operates from a 230 volt ac.supply 50hz
hello, john it says
ratings 100cm models
front left 1800 watts
back left 2400/1600 watts
dual elongated zone
front centre 2200/750 watts duel zone
back centre 1200 watts
front right 1200 watts
back right 2200/750 watts dual zone
thankyou
I,m not sure  if 5200 os for the pair or 1.
on the 90cm models it says  single ovens 3400 watts and twin ovens 5000 watts.
thanks I have stuffed it in the block but I cant smell a fishy smell yet. what am I doing wrong?
Find the spec plate on the oven, it could be on the back but most likely just inside one of the doors, this will give you the total rating of the whole lot.
make & model of the range might help.
hello,
What make and model exactly .............. not many have 2 supplies connected IMHO
