Can't you move any quicker?
You deserve a cigarette doing all that lot in one day.
I dont need one, im dont muck in on them now, i just check them and issue snag lists to the lads, they dont leave many snags though
The company i work for carries out 1 day rewires, normally 2 sparkies and 1 labourer, all chased in, capped up ready for plasterers to follow the next day.All chases done with chase machine and extractor, normally 2 lads chasing out while the lead electrician gets boards up and starts pulling cables in
Plasterers come in the following day? So when do they do the 2nd fix?
I used to do council house rewires (surface-3 bed) for the company I used to work for. 2 sparks. 4 days. Couldn't do it any quicker without been called back to sort out snags.
IMO nobody could do a proper, decent job rewiring a house, fully tested in one day. unoccupied maybe, but not occupied.
Plasterers come in the following day? So when do they do the 2nd fix?I used to do council house rewires (surface-3 bed) for the company I used to work for. 2 sparks. 4 days. Couldn't do it any quicker without been called back to sort out snags.
Inclined to agree there mate. If they succeeded I doubt it would be a very good job.
ive seen many of these '1 day rewires', by both council & mr electric.
never done properly.... the snag list is usually another days work. some of the re-wires are simply new DB & accessories. no bonding or earthing done in some cases.
worst 'rewire' ive seen was a new split load, with most circuits (inc all sockets) on non-RCD because of low IR tripping RCD. no rod, no main earths or anything. the odd accessory was changed, but still some broken left in place
