Ccnsg (Safety Passport)
alpha spark
Jan 24, 2012
765
Any one done it seen quite a few subby jobs that require it. Is it worth it.
Thoughts please
Did it years ago when my then employer was working direct for Corus as was then, & it was needed to work anywhere on site to do anything basically.
Will probably re-do mine shortly depending on which way work goes.
I found it easy TBH.
Cheers sidewinder
Are there different versions looking at a site and the cost varies from £140- over £200 ?
Mine expired in March would have renwed it if i had the money, used to be called a Scats card as i was told and you need it to get onto certain industrial sites. I had to get mine in 2010 when the firm i was working for had a contract relamping the road lighting at stanlow and tranmere oil renfinery.
