Circular Saw Blade.
Screwfix are pretty helpful on the counters if you want to see something. I'd take your blade in and hold it up against the Erbauer one. Pay particular attention to the bore as 5/8" ID is fractionally smaller than 16mm. Most importantly I would say is the blade thickness. I got a replacement blade from S'fix for my Skil brand saw. Unfortunately the new blade was thinner than the rivving knife! This one will fit for sure:
http://www.tizaro.com/product/PT1I4C/dewalt-dw9155-blade-18t-8in-arbor?utm_source=google&utm_medium=merchantUK&utm_term=power-tools--power-saws-and-accessories&utm_content=circular-saw-blades&utm_campaign=dewalt-dw9155-blade-18t-8in-arbor
cheers! i googled but didnt come up with anything.  Never heard of that company before anyone used them?
wozz,
Having owned & run a Saw Doctoring company in the past then, I can say, categorically, yes you can get a blade in the UK.
To spec it for you, I need the bore, the no of teeth, what you want to cut, the machine spec, & if the machine has a riving knife the thickness of the riving knife.
I can even get one "MADE" for you if you want! ;)
cheers lads,
onoff and sharpend had it straight away.
this is what you were after sidey:
Circular Saw Blade Carbide Tipped Blade Dia. 6-1/2 In. Number of Teeth 18 Kerf 0.059 Tooth Grind ATB Hook Angle 20 Degrees Arbour Hole 5/8 In. Diamond Knockout None Plate Thickness 0.039 In. Wedge Shoulder Ultra Thin Kerf Combination Blade For General Purpose Ripping Crosscutting in Wood Building Materials Finished Plywood Prefinished Materials For Use With Circular Saws
But at £20, buying off them isnt too bad, I just couldnt be bothered with the faff of import tax ect, looks like this company has already done that!
