Citroen berlingo
M107
Billy-the-Kid
Feb 18, 2008
5,561
28
Berkshire
My mate has a berlingo & it's fine on tick over but try to push the accelerator & the motor cough splutters & dies?
I'm thinking fuel starvation, but anybody got any other ideas?
It's a French van?
What do you expect to happen when you require it to do something?
- give in and surrender :D
:coat
Fuel filter comes to mind, failing that its down to fuel management system.
If the injectors are even slightly blocked this will have a dramatic effect on a deisel engine.
Another problem with deisel engines is the correct grade of oil used, some oils will turn to sludge, making the engine work much harder than needs.
A full service with a garage who understand deisel engines will probably sort out the problem.
