Of course not, they never trip out or cause problems ;My house is all 3036s.......just stating an irrefutable fact!
I do not have an issue with them!
Here you go: http://www.tlc-direct.co.uk/Main_Index/Consumer_Units_Index/Wylex_Std_1/index.htmlAssuming you can actually buy one of course .
I had a customer's father-in-law poking his nose into the extension they were having built, he told the builder he wanted a BS 3036 board " As thats what we have at British Rail"
Out of curiosity I asked the wholesaler ......... they couldn't source one on their system .
r.b We try to help each other on here but if you are working as an electrician you are supposed to know some of these things . What training have you had?When installing these new boards do I need to be putting in 25mm tails 16mm earth?although the wiring is red and black or can I just leave the 16mm tails red and black and 10mm earth in?
Would you? When wouldn't you?evans electric its only a question end of the day if I changed it with existing tails it would still work just asking about it should I be putting in 25mm a know I would If a complete re-wire
Have you not thought how he is connecting the new CU to the existing tails :innocentSo if you swap the tails how are you going to connect them, assuming it is a DNO head and meter
Is there an external isolator? If so what size tails feed it?
If no isolator then are you going to
Pull the fuse ,.......ILLEGAL
Connect to meter........Illegal
Do it 'on supply'...........not even worthy of commenting on
Get someone else to do it
Plead "fifth amendment "
Just saying
your supposed to be an electrician, yet you dont even understand the basics. maybe go get an office job instead where the worst that will happen is the photocopier will constantly print the same thing, instead of someone ending up dead through your lack of knowledge, which unfortunately i unlikely to be youevans electric its only a question end of the day if I changed it with existing tails it would still work just asking about it should I be putting in 25mm a know I would If a complete re-wire
I was just about to put that, as ever I was beaten to it!Have you not thought how he is connecting the new CU to the existing tails :innocent
