Hi everyone
I've been asked to install 3 sockets in a conservatory that is currently under construction. I have a couple of questions. Firstly the only available point of supply due to the location of the build is from a spurred socket in the adjoining room. The spur is a single socket but has a fused connection unit attached to supply a dishwasher. I am planning to install a fused connection unit and then feed everything else from this as the customer informs me that he only requires the sockets for lamps. Would this be acceptable? Secondly, the customer has requested that the cabling is installed under the soon to be poured concrete floor. I would appreciate any advice on the best method to achieve this. My initial thought was to use 20mm PVC conduit. Would this be acceptable and are there any rules or regs on routing or number of bends etc.
Sorry about the long and probably ******* question.
Thanks.
Thanks.
