Sudden increase in usage after electrical work
I agree it's Combi boiler, so water cylinder no longer required.
But did the installers of the new boiler remove the cylinder ?
Has the old immersion heater been powered by the CU replacers ?
Not sure why your pushing the immersion heater route even if one had been left connected I would think it would have burnt out by now as the water evaporates from the cylinder also there would likely be a noticeable increased level of humidity / condensation in the property
Op said : There are no immersion heaters or anything like that on the property.
The water feed to the tank would keep the tank full.
But we'll see what the OP discovers at some point.
Clearly you have little understanding of plumbing, when changing over to a combi it is normal to isolate the water feed to the tank so you can divert the hot water pipe from the tank to the combi boiler
I have successfully installed a complete central heating and hot water system myself, so I do have a tiny amount of understanding :)
So I'm aware how a Combi should be installed.
My premise is that the combi was installed but the installer left the cylinder, pipework, and wiring.
Then the CU was changed and the electrician wired up the immersion and it's switched on.
The OP doesn't own the house so may be mistaken about "no immersion", we'll see, if he ever comes back after inspecting the house.
Has anyone come up with a likely solution yet ?
There are certain questions that the Op hasn't replied to yet.
But even if there is an immersion tank being heated, can you explain why there would be an increase in consumption to previous ? The hot water would now be supplied from the combi.
The Immersion heater, if there was one for emergency use, was off, hot water was supplied by the gas boiler.
The new CU was installed, the electrician wired up all the existing circuits, and turned on all the breakers.
But I'm getting tired of saying the same thing over and over , so let's see what the real cause turns out to be.
You are suggesting there is an immersion heater, heating a now unused tank. If so it would either have reached temperature and cut off, so it's usage would only be every now and then to make up for heat loss from the tank. That would not account for the extra usage. Or the tank would be sitting there boiling it's head off and the house would be full of steam, or worse.
But until the OP bothers to come back and tell us more, this will remain a mystery.
I'm struggling with this I cannot think of any reason to leave a hot water cylinder full of water for an emergency the plumbing of change over valves would make it not worthwhile, then you also have to consider the potential health risks from legionella having stored water which would need regular heat cycles and tank pasteurisation to prevent it
So no local isolation on the immersion then or has the electrician accidentally turned that on as well
If you took the time to read the posts countering your assumption you would not need to keep saying the same thing over and over
They could have had a Combi previously, and have now had a replacement Combi so never had an immersion in the first place.
The OP right from the start said that there is NO immersion heater or anything like it.
Third liner of the OP's original post:-
"There are no immersion heaters or anything like that on the property".
Could it be that most of the meter readings have been estimated, and now you have had an actual reading which has pushed up the amount of units used hence the high bill, or as mentioned it possibly be a faulty meter. I would contact your energy supplier and ask for an accuracy test on the meter.
Looks like the OP has deserted us.
Or maybe he's still looking for that illusive immersion tank
