confused
soulman
May 17, 2010
334
can you guys shed some light on this for me as i am confused. two terraced houses next to each other, earth rods side by side, both houses have old ELCB's. Would an earth loop impedance test have caused next door elcb to trip????
thanx in advance
would this have travelled up his earth rod and tripped the elcb cheers
Yes
This was a common problem with the old Voltage Operated Earth Leakage Circuit Breakers.
Another good reason to ditch them and install RCDs
Two Volt Op ELCBs should never have had Earth Rods within same area of ground for this very reason.
:red card
