Phil Lowndes
Hi, this is my first post so here goes.
Currently in my kitchen I have 9 x 12v halogen lights that I would like to change to gu 10 led. Each one is attached to it own transformer which is attached to it ownn junction box on a looping system. The junction boxes to each transformer are earthed. I would like to upgrade to mains gu10 and do without the transformers. What is the best method to do this. I have been told that all i have to do is remove the mains from the transformer and wire it into the new fitting. Is this true. Also some of the the fitting show an earth cable. Does this mean I need to run a earth cable from the junction box to the new fitting. Also does the fitting need to be firerated as there is a bedroom above the kitchen. Also can I use any gu10 led bulbs obviously taking into account max wattage of the new fitting.
Any info will be greatfully recieved.
Phil
Phil
