TheMadHatter
As it's my first post, before I start a bit about me. My electrical experience is mainly limited to rebuilding motorbikes and cars, although I've watched the old man make alterations in the house and am aware of most of the common precautions as well as safety needed when handling something that can kill you. I've always enjoyed my physics, especially circuit building etc and understand the relationships between resistance, voltage, current and power - their units and so on. So I'm green when it comes to making alterations to stuff in the house but not quite the green green grass.
So,
I've recently purchased a couple of UK mains table light fittings from a high street retailer, which will look better wall/ceiling mounted.
I am hoping to remove the plugs, feed the wires through the ceiling and wire them both into a single remote controlled unit (so they both respond to the same command) and then connect them to the ring main? However I'm struggling to work out the exact componets to go for. I'm certain I need a remote control and a transmitter, from what I've seen Byron seem to do a good set. I'm looking at the Byron RS 63 as I'm only looking to have 60w bulbs in both and hope that the Home Easy HE200 transmitter will work with this remote control.
Firstly does anyone know if these components will work together? If not, do I need any more components? Secondly, is there any issue which will arise from my decision to use two standard plug in fittings in this way?
Or am I making errors here and do I need to be looking in another direction to find a solution to this problem?
Thanks in Advance.
The Mad Hatter
So,
Thanks in Advance.
The Mad Hatter
