Convert internal light switch to control external light?
Trev01
Oct 30, 2023
10
6
Appreciate some advice here please.
I want an outdoor light above the back door that is controlled by a switch, and wondered if i could change the use of my internal switch that I don ´ t use.
In the lounge I have 2 light fittings at opposite ends, one is a 2 switch that controls both lights, the one by the back door only controls the fitting by the back door - it is this switch i would like to use for an outdoor light. Although this switch works, we never use it.
I have attached a photo of the switch, and a very poor sketch.. so sorry
I guess black and blue wires are neutral, but the yellow wire?
If it can be done which wires do i terminate, and which is the live to connect the outdoor light?
Nearly forgot there is an earth connected to the housing.
Hope this is an easy one, and can be done. Thanks
Dec 8, 2016
2,050
437
Blackpool
Sorry to disappoint you, and I don't really understand your description of the current arrangements, BUT that looks like one end of a two way switch system It is highly unlikely than any of those wires is neutral or they wouldn't be connected to the switch.
Trev01
Oct 30, 2023
10
6
Thanks for the reply... yes, it is a single switch on the end of a 2 way.... shame..... will have to look at other options for an outdoor light..... a torch by the door perhaps :LOL:
Trev01
Oct 30, 2023
10
6
It needs connecting to the brass earth terminal of the switch plate, below where it says "Must be earthed".
Gotcha - so just connect a fly lead from the switch to the earth in the housing where the other earth is connected?
Fleeting
Mar 27, 2021
1,430
406
If the other earths are long enough relocate to the front plate or a fly lead as you suggest. If you have similar switches elsewhere you may want to check them.
SPECIAL LOCATION
Trailer Boy - Electrician.
Mar 28, 2008
14,179
832
Just to add some additional background info that may help you understand the arrangements you currently have...
(a) a standard single light switch does NOT need a neutral connection... just a permanent live from the supply and a switched live out to the light fitting... The neutral connection is at the light fitting.
(b) for two switches to operate the same light a three core cable is required between the two switches so two alternating switch options are possible.
(c) UK cable colours for fixed wiring changed during a phased change-over between 2004 to 2006 Old Live and Neutral 2-core + earth cable colours were Red (Live), Black (Neutral)
[New colours Brown and Blue]. Old three-core cable colours were Red, Yellow & Blue.. ALL live! [New Brown, Black, Grey]
(d) Though frequently not used, for standard single switches Twin Red or Twin Brown 2core + earth cables are available! But if a two core cable with Black or Blue conductors is used for a light switch they should be over-sleeved or taped with Red or Brown to indicate they are actually Live conductors!
(e) Red, Yellow & Blue are ALL recognised as live conductors under the old fixed wiring colour identification. So Every wire connected to your switch is either permanent live or switched live.. No Neutrals needed!
(f) The Red cable sharing with the Yellow, and the Black cable sharing with the blue are the two actual switch in & out conductors!
Hope that helps a bit?
Trev01
Oct 30, 2023
10
6
That helps out a lot, thank you so much for taking the time to explain.
Trev01
Oct 30, 2023
10
6
I went round the house and all but 1 light switch the earth was installed to the housing.
I have corrected this now, thank you all once again.
