Hi All, Just joined as I have a question, which is:
What size MCB should I use when replacing a 30 Amp 3036 fuse on a ring circuit that uses the old odd sized 2.5mm t&e with 1.0mm CPC. I have been reading up on calculating the CPC from cable lengths, fault currents and all sorts and have got completly confused, so help please! many thanks, Tom
