correction factors
jg90
Jan 27, 2012
12
Can anyone tell me how to calculate the correction factors for a cable selection I have not done a calculation since college and I am struggling to remember how to calculate it I have examples I done from college but everytime I tried to calculate to find out the amps I was getting lower answer than the ones in the examples I know all the tables to use and that just think I'm doing something wrong with the calculater ?
Multiply the c.c.c of the cable by each of the given factors in turn.
So if your correction for thermal is 0.5, and the one for rewirable fuses is 0.75; and your selected cable would be, say, 100A
100 x 0.5 x 0.75 = c.c.c. after correction factors.
Does that help?
KME; the way your post looks the conductor
size is decreasing and it should be the other
way.
Is it not In divided by 0.5. 0.725?
Correct me if I am wrong.
KME; the way your post looks the conductor size is decreasing and it should be the other
way.
Correct 100
No!
If you read my post properly........
If you`re calculating the corrected current-carrying-capacity of a cable, it will get lower after correction factors applied; NOT higher.
If you`re doing the opposite, and trying to find the necessary tabulated value, then you divide.
:coat
No!If you read my post properly........
:coat
KME; It never entered my mind that you could be
incorrect but I was interested to read how you applied
those factors.
As I looked at this I had the OSG procedure in my head.
Can anyone tell me how to calculate the correction factors for a cable selection I have not done a calculation since college and I am struggling to remember how to calculate it I have examples I done from college but every time I tried to calculate to find out the amps I was getting lower answer than the ones in the examples I know all the tables to use and that just think I'm doing something wrong with the calculate ?
From your answer I presume you have a copy of the on site guide. Appendix F, as well as hiving the tables, also has the formula and procedure written down. As suggested the only way to offer any more advice, is for you to give the actual figures you are tying to calculate and your answer. Then no doubt someone will be able to see which part you are doing wrong.
