sorry apple, I dont understand the first sentencei cut an off cut about a foot long then push into each side of corner and mark top and bottom, this will give you both points to mark on the cut.i use cove adhesive to bond it up. mark the bottom line and tack small nails to hold the cove in place, hold sections up before applying gloop to make sure cuts and corners are good to go. bonds quick so just nail a few on the top to hold it there. after a few lenghts it will be a doodle.
ggod luck..
