Outside Mains Sockets
I don't think that is necessarily true as more consideration is given to the method of erection than it is in the domestic setting
Oh that's definetly true, I've spent 30 years in factories, and 20 years working in domestic. I've never seen rusted out swa in domestic.
Now if you think swa is not mechanically protected, then do pray tell us how you would install the cable?
seen plenty rusted galv in SWA
But how long had it been there?
I never figured out how this internal SWA joint at a domestic garage CU feeding a "summerhouse" outbuilding got so bad.. As the cable colours suggest it cannot be that old????
Unless "Bob The Builder" left the unterminated, unprotected end of the SWA, open to the elements for a long period before he got round to putting the roof on the external, remote, unconnected garage structure?
IMO, if the SWA needs additional protection, you could put it in metal conduit.... I'm sure there are extra measures that could be added. Is it needed? Who knows... See my post 17 😁
Or the OP may come back and give extra info...
Seen quite a few rusted out SWA's in domestic properties outside, garden and pond lighting being the favorites, a lot down to poor installation, leaky fittings or wrong glands
Without eyes on it is difficult as no one size fits all in the past I have installed SWA in conduit, deep channel, heavy duty cable capping to suggest a few ways
makes you wonder if the quality of the galvanising has declined.
I used to do a lot of work in Salcombe, which suffers from salty sea air, corrosive enough to reduce a standard outside floodlight (the black painted aluminium cast type) to a furry mess of corrosion in a year. An old school I used to work on a lot, converted to flats, had all the incoming supplies in an a short tunnel, door one end, open to the sea air the other end. The conversion to flats was old enough that all the swa submains were 2 core with armour as earth. The DNO fuse board was rusty metal - I asked them to inspect it, the sub main switch fused isolators were ok, and all the swa was fine, apart from the end at an old lamp post that had been leaking water for at least a decade. But that was all old stuff and properly terminated. Likewise a far newer block of flats I maintained, seaview below. Which brings us back to quality of materials and workmanship. https://maps.app.goo.gl/5uCXwdUmRBWrzwiQ9
As soon as you cut the armour the ends are no longer galvanised. Any moisture that comes into contact with this will create corrosion and this will creep up the armour.
