Crabtree Polestar RCBO alternative
explosif99
Dec 31, 2011
2
Kernow
Anybody got any ideas for an RCBO that will fit a Crabtree Polestar CU?
All I seem to be able to get hold of is Starbreaker which don't fit.
I don't usually use Crabtree so I'm a bit in the dark so to speak!
I know you shouldn't mix makes but it seems I have no alternative as customer won't pay to replace CU!
I thought Polestar were commercial boards !
Crabtree make RCBOs in the Polestar range so a 32A is a 602C/323 which is a type C DP ( cost a fortune I'd guess)
---------- Post Auto-Merged at 18:33 ---------- Previous post was made at 18:31 ----------
Stepps , Starbreaker is the plug-in one which nothing else fits .
---------- Post Auto-Merged at 18:35 ---------- Previous post was made at 18:33 ----------
Anybody got any ideas for an RCBO that will fit a Crabtree Polestar CU?All I seem to be able to get hold of is Starbreaker which don't fit.
If you fit another make it will be a million times safer !!!!
thanks Deke,
well then polestar is a fairly standard size I'd say, but I would have said that the starbreaker were harder to get than anything else.
Guys, many thanks for your help. I'd hoped a Wylex would fit as they do look very similar (probably made in the same factory).
I'll give it a go and post the results for future.
