crabtree
Erm, yes. all CU's have a busbar, otherwise there'd be nothing to link the MCB's to.
On a Crabtree board the Busbar is a plugin variety that sits behind the MCB's, similar to the Square D type. If you get a look at an MCB you'll see where the busbar goes.
Must have been a Starbreaker, they are the safest to work on .
But of course you would always switch it off before even looking at it , would you not ?
So it doesn't matter how safe they are does it . H & S ... H & S ...
Phewww !!! I could hear the guns being loaded as I typed then . ;)
Must have been a Starbreaker, they are the safest to work on .But of course you would always switch it off before even looking at it , would you not ?
shrouded busbars are not always safe to work on! ive managed to get an earth into the live part, and blow it clean apart where it was touching metal case!
