Cutting boards
gselectrical
Oct 13, 2009
627
Evening all. I need to purchase either a circular saw or a reciprocating saw to cut floor boards. Can anybody recommend any? Cheers
J
I use a ryobi battery powered circular saw, does the business not had any problem with it. A near miss the other week as someone had clipped cables to the underside of the floor boardsheadbang
Circular saw. Reciprocating saw is definitely not the tool for the job there!
As for which one, depends how much you're likely to use it and for what. I have a Makita 5703RK, had it for 12\13 years or so and was
Fein Multimaster for me
Now, I knew someone was going to say this. Do you actually use the Multimaster for cutting boards up? I'd rather use a circular saw for the most part, keep the Multimaster for best. ;)
Don't do what I did. I bought a Skilsaw for $80 in them thar United States. It was a great bit of kit. Until I needed a new blade. Buying a new Makita was cheaper.
But whatever you pick, as Lurch says, floorboards, recip saw, oh no. You won't get a very straight line, since you'd be cutting through a joist. But there's a good chance you'd end up saying... **** get me a towel. And really quickly. headbang
2nd Multimaster. They even do a dpth stop accessory. The bi-metalic bit doesnt care about nails in the way either ;) .
Although perhaps it takes longer with the Fein than a CC, you don't get the overcut, but I guess if you had a lot of boards to lift then maybe the CC makes sense
Mind you I wonder if I could use my impact driver to cut boards ; \
I've got a cheap circular from Wickes for ripping through the boards and a Bosch (Fein) jobby for smaller work when I don't want any mess and can afford to spend a bit longer cutting them.
Be aware the Bosch will still slice a gas pipe !!!!
I've got a cheap circular from Wickes for ripping through the boards and a Bosch (Fein) jobby for smaller work when I don't want any mess and can afford to spend a bit longer cutting them. Be aware the Bosch will still slice a gas pipe !!!!
Talking through experience is that.
Cheers lads. SITE (aka makita) 110v circular saw I think, what u do you think? J
If I had a load to cut then I wouldn't use the fein but my 18V circular as that would be faster but I would have to be virtually lifting the whole floor for that.
I'd be happy with that I think.
I had a Makita 110v...got rid of it and got a cheapo because I got fed up lugging the transformer around
Why not just get a Makita 240V then? Most of my stuff is 110V as it was all for building site use, and once I've got the transformer out on any other job it's out then and most of my tools are 110V. If I was purely doing domestic then I wouldn;t bother with 110V if I started buying tools again.
I wish I had bought the 240v instead:( :(
I bought the 110v when I went self employed thinking that 240v would be no good for site work... and seeing as I don't do site work, when the blade went I got a cheap 230v one to replace it
