Cutting thick cable
m4tty
Scaredy cat™
Feb 5, 2009
5,612
What do you use to cut thick cable like 25mm meter tails.
Simple question but wondered if there were any tricks to make it easier or any decent tools you use to cut them.
angle grinder with .6mm cutting disc for BIG cables
like butter
Hi,What do you use to cut thick cable like 25mm meter tails.
i use these for just about everything. will go through 35mm tails, or 50mm stranded
