...........As a heads-up folks,
Bought one of these aro 12mnths ago and have discovered some annoying issues with the tester.
The rotary/function selection switch behaves such that it doesn't always make contact internally, but of course you don't realise this at first!!!
As such, I discovered this whilst 'Auto-Testing' RCD's in a 3-story dwelling - and yes I was on the 3rd floor and the CU was on ground floor !!.
The tester starts, so you run down to the CU only to find the blasted thing has decided not to complete the test's...... it switches itself off?
The tester also screws-up on Loop & Ze mode!
After expressing my annoyance w/DiLog, the rep kind of admitted to a 'known issue' with this switch ........ great - NOT.
They are currently reapairing it under the 2-yr warranty, and have had it for 2-weeks now.
I will be calling again tomorrow to get the thing back.
If you're looking for a new tester you might want to avoid this one!
Rgds,
JimG.
Rgds,
JimG.
