Hi all
One of my storage heaters is not charging overnight. I took the front panel off to see if the reset button had popped, but unfortunately it was not that. My next check was the elements, but I can't see any breaks in them. There are two things I have noticed, but I don't believe that either has anything to do with the lack of power. One is the cracked housing you will see in pic 5. The other is that the element on the right plugs into a terminal housing that seems a little loose. The wires that go in and out of that terminal block seem sound, though.
I've attached some pics in the hope that one of you chaps will be able to advise me. All help gratefully received.
Regards
BillBrum
Regards
BillBrum
