Diodes
echelonone
Mar 9, 2015
2
NY
I need to control a 12vdc relay via 9 different 12v sources. If I put a diode on each of the 9 12v lines to the relay, will the diodes prevent back feeding on the other 8 lines/sources when only 1 line/source is active/on?
Well I make that about 50 words over 3 posts in less than 1 hour...
answer within 13 minutes...
Thank you within 56 minutes of original post...
IS THAT A FORUM RECORD ????
:eek:   :happy bunny:   :rolleyes:
