Rino125p
Hello Guys,
I have found this forum when I was doing my research, and it looks that you guys know what you're talking about and generally everyone is very helpful.
I have electrician's experience from other country (I was qualified to work on up to 1kV) and electronic education background. Then I moved to IT sector years ago so I'm more DIY now that qualified specialist.
The rules and low you have here in UK is way different to where I came from, and I'm really confused what I ca and can't do by myself. I hope you will kindly be able to give me some advice and show me the right direction.
My plan is to install the battery storage system at my house first, then switch to Octopus go tariff. I would charge the battery from grid in 4 hours window and use it during the day to power the house.
Later I plan to add solar panels (around 2-2.5 kW) to reduce grid usage.
I’m not interested in of FIT, just a self-usage.
I planned to buy Growatt SPF 5000ES – 5kW all in one inverter, but I can’t find any UK seller all chinse or AU.
However inn few threads I seen you talking about 3.6kW inverters to be allowed.
I don’t want to put myself in the situation where someone will come over to me and fine me for installing illegal equipment (house is still on mortgage and needs to be insured).
Please! I’ll be so grateful for any advise on what Can I do by myself, which inverter to use etc. Maybe someone did similar thing already and could share his experience.
With Kind regards
Arthur
This thread has been split to avoid confusion as it was hi-jacking a similar one
With Kind regards
Arthur
