Rob_the_rich
Sock Muncher
- Mar 2, 2010
- 1,343
- 27
@Sidewinder was it you who was asking for dodgy RCDs?
Recently tested an MK Sentry DP two module 80A RCD (tested from plug socket) and it failed to trip on all x tests. I then pressed the test button and it tripped. But still failed to trip with the auto test. TNS supply, Good Zs results.
MFT is recently calibrated and tests worked fine on my extension lead RCD.
The next day I went to site with replacement but thought to test again before taking it out and it passed all tests.
Swapped it out anyway and the old one is sitting in the van.
Did you want it?
Edit; test button has probably never been used for about 8 years since the CU was installed.
Did you want it?
