Just as at the end of the news.. they normally have the more light hearted new items..
We could finish this thread with a nice little schoolboy's practical illustration..
Apparatus:
1 x 230v Supply
3 x Bits of wire
1 x Small tub of Tap water
1 x Light bulb and holder
1 x El-cheepo Maplins Multimeter
Method:
Connect a circuit from supply through tub of water, then to bulb, & back to supply.
Connect multimeter between Neutral and the tub of water, (set on AC voltage).
wired like this
Switch on power.
Results:
The light lights.. electricity travels through tap water.
It can be seen that the water was at 215v ac potential with ref to neutral.
Conclusions:
The tap water conducted mains electricity..
Because 215v is above the generally accepted safe 50v touch voltage
and is almost within the acceptable supply voltage range 216v-253v...
DON'T PUT YOUR FINGER IN THE WATER!!! :^O :^O
Comments:
The tub is plastic & approx 50mm square,
the tap water had no additives.. (as supplied by Mr severn & Mr trent!).
Other points for consideration:
Why hasn't Spec Loc got something better to do.? :|
Why isn't he working out the cost for the quotes he should be writing? ?:|
Why has he used RED wires for LIVE AND NEUTRAL connections to the snap block?
Why is he so easily led into fruitless exercises by Extn 15!? :^O
DISCLAIMER:
Children please do not try this at home!.. Ask an adult for assistance ; \
