NigelDent
Dear all,
I have had a new kitchen fitted and I am having spurious trips on a single circuit. The trip is not when an appliance is running and tends to be late in the evening or through the night and it is not happening every day. The trip takes out the RCD and the MCB but allows a full reset straightaway. The circuit has on it:-
Dishwasher (new) on an isolation fuse switch
Washing machine (old) on an isolation fuse switch
Velux skylight (new) on fuse without an on/off switch
Extractor hood (new) on an isolation fuse switch
Electrics for gas hob (new) on a plug switch
Microwave plugged into socket
Digi radio plugged into socket
Kettle plugged into socket
Toaster plugged into socket
LED underlights on isolation fuse switch
Dining room radio plugged into socket
The electrician who carried out the work has been back to our house & isolated everything and checked the current and earth and the circuit is clear.
Yesterday (Saturday) was the worst day so far ! we started the morning with everything connected and the fuse blew 15 times from 10.30am to 1am, each time I removed an appliance from the circuit until the last time there was nothing on the circuit at all apart from a dining room plug socket switched in the on position but no plug plugged in (didn't spot it until this morning).
Today (Sunday) fuse blew when turning washing machine isolation switch back on (1pm) and then again 30 mins later.
The last thing to isolate yesterday was the extractor hood, with the hob electrics before that.
This has been happening now for 2 weeks and we cannot get to the bottom of the problem.
Any help or advice would be much appreciated as this is starting to effect our day to day life as we have to keep resetting the fuse & turning everything back on.
Many thanks
Nigel
Many thanks
Nigel
