This could be a question without an answer, or open a can of worms.
Do you guys know of any regs regarding the depth of void to put them in. I personally do not like them and am wary of putting them in a ground floor ceiling. My concern is the heat dissipation, (or lack of it).
If there are no set guidelines do you have a minimum distance between the fitting and the upstairs floorboards that you use. I have seen some worrying photos of very charred joists!
Any guidance or help gratefully received.
Cheers
Cheers
