Unfortunately the digital regs isn't a pdf, or a single document that can be run through a file compare.
Yeah it doesn't show the differences, no vertical lines to the side of new regs. Its a case of reading PDF and checking byb. What a pain.
This one is worth a comment or two.
SELV cables can now be buried without requiring any armour etc
wrong type of burial. refers to cables buried under ground. basically, DIYers can now buy cheap lights that run on 12v and no worry about non-compliance with regs when they bury that little 2x 0.0000075mm² cable. probably a better marketing oppotunity for manufacturers too, 'oh look, our lights come with a cheaper cable that can now be buried direct'Well, how about PoE everything then. Huge 48V PSU at the CU, wire house as normal, fit every outlet with 1:5 transformers. Bonus of having 240V at all outlets.
some of the changes....
all sockets upto 32a must be RCD protected, no omitting an RCD if your risk assessment says so
What does that mean exactly Andy ?iirc the lines to show the difference are only between amendments & not editions
FFS. so we now have to provide the 'multiple' part of the DNO's PME
I think we need a get out that non standard or commando sockets can be left without RCD, or have a a proper label that everyone knows means the socket is not for use anywhere else.
or will we have the senario of firms saying OH ! they were installed last year under the previous regs. ?
I have to do stuff but will be back later .
Sidey ....is there anything there we could all object to , in our own ways ....never know , might make 'em think twice . ?
seems as though we now have to install an earth rod regardless of DNO earth or not... presumably so the DNO dont have to mess about putting their own earth rods in...
Most electricians haven't got a clue about the changes.
Yes this ensures that compliance with ESQCR does not cost the DNO's anything, that cost is passed on to the householder, and the explanation for the extra cost is passed on to the electrician, so the DNO can swan off into the night making even more £M of profit whilst the house holders of the UK subsidise this again, regardless of the legal requirements of ESQCR.seems as though we now have to install an earth rod regardless of DNO earth or not... presumably so the DNO dont have to mess about putting their own earth rods in...
I'd say that was certainly the case for employed electricians . I think the self employed are for better informed TBH.I think most just don't care, they aren't listened to and no-one really checks to see if they are following them anyway. That's my stance anyway.
I got a phone call today, "you haven't re-registered with the scheme this year". Paraphrased my response was "I CBA but I should as I still have loads of work that needs notifying". They just told me the price was still the same so I can just call them when I want to join again. That was it, literally only cared about the subscription costs.
Not too long ago we did some work for a factory who had their own maintenance sparks . We put a new TPN board in and it turned out he was not familiar with MCBs . Not really his fault , the place hadn't moved on from the early 1960s , mostly Bill rewirable boards , old machinery, guy worked there on his own with no external input for years.Most electricians haven't got a clue about the changes.
