Driveway Light
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Customer has asked for a price to install mini lamp post light at top of driveway. The CU is under the stairs in the middle of the house and would be a nightmare getting cable from here to outside as laminate floor etc.
Any suggestions where else power could be taken from?
I know it needs armoured cable which will be buried but if I could get power from ring? fused down? I know it would be better on its own circuit as adding outside stuff onto ring mains is asking for problems.
Any suggestions?
Thanks for all your help and not taking a pop at me as i am asking some basic questions but im a worrier and want to make sure ive done it all proper and correct.
Matt
If you come off with a rcd spur unit remember discrimination with the rcd on the cu if it as one on the circuit you spur off
Does the property have a garage with power ? It might be easier running your swa from there depending the set up of course . Just an idea as taking a supply from the cu could be difficult depending on the location but has been suggested before an fcu and rcd protection from the ring main is a safe option and means the lamp can be isolated too for maintenance.
Hi mate,
How can you achieve discrimination if the CU is split load (both sides covered by 30 mA RCD) and you want to install a RCD Spur unit as they are 30mA too?
Cheers
Hi mate,How can you achieve discrimination if the CU is split load (both sides covered by 30 mA RCD) and you want to install a RCD Spur unit as they are 30mA too?
Cheers
The only real way to provide descrimination with RCD's is for the upstream one to be time delayed. If the circuit is already protected by a 30mA RCD then I would not worry about another one.
Also (not wanting to start ANOTHER exported earth thread) be careful what you do with your exported CPC.
FCU spur off ring main then adaptable box for the SWA up to the light fitting itself I would think is the safe option if the ring has already got an RCD protecting it . If a fault does develop in the light fitting and does trip the RCD on the CU then at least you have the option of switching off the FCU and resetting the RCD so power can be resumed on the ring until the fault is cleared on the light fitting . How far would the fitting itself be from the house and what earthing arrangement is there . I'm thinking outside equipotential zone ( I feel an exported cpc thread coming on ) :Blushing
...and what earthing arrangement is there . I'm thinking outside equipotential zone ( I feel an exported cpc thread coming on ) :Blushing
Just remember I said above I didn't want to start one of those again ;) .
