Dual tariff consumer units?
lilman
Jun 17, 2008
209
I need a new consumer unit that can house both peak and off peak supplies in one unit. I know they exist somewhere - anyone know a good supplier/brand. Basically I would like one that has main switch/dual RCD protection on one side, and main switch/RCBO (night storage heaters) on other side.
Thanks all
Trying to free up some space - will probably end up with 2 boards though.
MK do a multi incomer kit for the sentry range of consumer units.
If you've got the width a 21 module units will give loads of flexibility or you could use a stacking kit to stack two smaller units vertically if you don't have the width.
It might help us to help you if we knew how many outgoing ways you need in total and the split ratio. Also, what is the maximum width available to you in the fitting space?
There are currently 6 circuits on standard board (cooker, lighting, 2 ring finals, 1 immersion and radial/boiler), and 4 on off peak (3 storage heater and immersion). Property is a flat.
Width not too much of an issue, height is though. Currently the off-peak board is below the other board, but needs to be moved up.
MEM do a dedicated dual tariff board. Fitted a few and worked well, I used rcbo's instead of two rcd's though
Used a MK split load arrangement with 3 neutral bars.
1 side for main switch RCD (off peak) + 4 mcb's
2nd side for RCD + half off peak ccts
3rd side for RCD + other half of circuits , incl 2 convectors for storage heaters
