- Dec 25, 2011
- 5,470
- 80
Possibly something that many know already but.........if any one had one of the old grey wet n dry vacs from Wickes then the Earlex WD1000 is pretty much the same model. I had trouble getting spares from Wickes and ended up buying some RUBBISH filters off of eBAY - really useless! Anyway I found that TLC do the Earlex range. ONE TIP THOUGH: The "Combined Wet and Dry Filter" doesn't push all the way onto the Wickes cleaner so you need to drill about a 10mm hole in the plastic of the Wickes one for the filter's retaining clip to go through. Once done it's perfect.
Wished I'd done this mod before I used the wall chaser!
http://www.tlc-direct.co.uk/Images/Products/size_3/EXWD1000.JPG
