sarusystems
- May 29, 2012
- 1
- 0
HI looking at these from Poland has anyone installed one would you recommend an independent consumer unit with 16mm cable for the above
Technical data:
· Wall mounted central heating system · Air temperature adjustment range – depending on the type of room thermostat
· Electronic system fuse – 500 mA
· Hydraulic resistance – negligible, small
· Factory test pressure – 12 at., design pressure – 6 at. (safety valve 3 bar, other valve on request)
· Weight: ~22kg (depending on power rating)
· Water volume inside the boiler
· Efficiency 99.5%
· IPX2 , class 1
· Step less temperature adjustment 5÷90°C ( floor 5÷40°C )
· Electronic system functions:
· Control: room, floor
· Multi-functional LED display
· Automatic power selection – by 1/6 (by 1/3)
· Manual power reduction 33-67-100%
· Heater operation time measurement – wear optimization
· Smooth on/off section switching
· Pump operation time-lag
· Water temperature measurement and stepless adjustment
· Diode boiler operation displays
· Compatible with all types of room thermostats
(dry contact)
[SIZE=9pt]FULLY INDEPENDENT SOURCE OF HEAT (CENTRAL HEATING SYSTEM) - EKW 18kW AsZN boiler equipment[/SIZE]
