Electric hob - Replacement
Dambo
Oct 7, 2009
473
Hi guys, just after a bit of advice on this one if possible:
Went to a property yesterday evening. The customer has an electric oven and a gas hob. She wants the gas hob changing to electric (she's already purchased the hob). Regarding capping off the gas supply to the current hob - Is this something I should be doing myself or will she also have to get a gas man in?
Capping off ??????
GAS MAN !!!!!!!!!!
dont touch it your not insured for it and if it goes wrong you are in the big poo poo
Don't touch the gas unless you qualified and gas safe registered, the customer should contact a gas fitter to carry out removal of hob...(unless you already know one)
I can only echo the above...
Don't touch it - get a Gas Safe Guy in. :)
A Gas safe guy told me that the bayonet type fittings utilising a flexible hose are no longer allowed to be fitted, and all new installations of hobs/cookers have to be hard fitted. i.e. soldered and compressiion to isolating tap.
Anyway, NOT our job - remember the recent explosions!!!! Touch at your peril
(I know - we have all done our own !!!!!!!!!!!!) :eek:
A Gas safe guy told me that the bayonet type fittings utilising a flexible hose are no longer allowed to be fitted, and all new installations of hobs/cookers have to be hard fitted. i.e. soldered and compressiion to isolating tap.Anyway, NOT our job - remember the recent explosions!!!! Touch at your peril
i doubt it. for hobs, it can easily be done (with oven removed). but gas ovens or free standing will still be done with a hose. there is no way you connect direct to the back using copper
Thanks guys. I'd assumed it wouldn't be down to me to sort but I thought it best to ask. Andy, i'm with m4tty i.e. no idea what a drop test is!
Plumbers shouldn;t be doing any gas work either.
A U gauge isn;t the only type of manometer out there BTW. ;)
