Just been asked to fit one of these in place of an original. Whats the crack with them? Do I disconnect the old one from the spur pull out and put new one in with some sealant? Never done one?
is it an exact equivalent dimension item you are replacing..... :| ?:|
Not to bad if yo need to make hole bigger, but can be a bit of a sod if original hole is already too big and new item would just fall through!!!! :_| :_|
Other than that.... its a Doddle!!! ; )Guiness Drink
