Hello, I hope someone out there may be able to help.
We have a Triton Caselona 2 Electric shower.
It currently cuts out when the dial is turned to the hot water setting.
We had an issue several months ago, when the pressure release device kicked in,releasing the little prd ball, and letting water out of the bottom of the unit.
This was quickly fixed with some replacement prd balls.
A couple of days ago, the prd device kicked in again. I cleaned the shower head with descaler, put a replacement ball in the prd, and turned the shower on,cold setting. OK, then 1 bar hot.....bang the prd goes again.
prd ball replaced again with another new one. Shower head taken off completely, hose checked for kinks etc..looks ok. switch on shower via cold setting set to max.. ok.. switch to 1 bar hot.....bang! water cuts out again (each time this happens the pull switch turns off,as does the main shower fuse under the stairs)..
PRD checked again, this time ball is still in place ? everything put back together, and both shower head and hose removed.
Shower set back to cold, max setting, ie 8,, switched on, ok,, then dial set to 1 hot bar,still on max 8,,, bang !! water cuts out again.
Could it be something to do with either the main fuse, or pull switch box/fuse ?? Or something else entirely ?
Many thanks in advance for any advice and help
Anthony
Anthony
