Electric shower solenoid
Feb 16, 2018
8
Coleford
Hi all
Where would I find a solenoid for a shower unit Gainsborough 2000x?
I've come across a Gainsborough 2000x shower. Which is producing no water put is powerng up, checked online for advice it said it would be the solenoid and i had to test and replace. I tests the ohms and it's seems fine and it getting the reading of 3.657. I've removed it now where do I buy a new solenoid from?
Thanks pete
Hi all
Thanks pete
Doesn't that mean it's NOT the solenoid?
Have you checked if any power actually gets to the solenoid?
I do hope you haven't got 3.657ohms across a 235.6v supply as by ohms law that would suggest a lot of amps will be flowing.  I=V/R.
Doc H
That would be for DC, AC it’s an inductive load which has a higher apparent resistance.
Its going to need to be one helluva lot higher or the shower would be drawing more current through the water inlet solenoid than the heater elements. The point being the OP has no mention of unit of measure for his "suspect coil"  ergo testing with a DC multimeter; 3.657 Ohm = probably faulty,  3.657Kilo-ohms = probably ok. Could end up replacing something unnecessarily.
Tested the voltage between live and neutral coming in to shower it was around 240
Tested between live coming in and - coming from the solenoid it was around 240
Tested live coming in to + solenoid there was very little reading
Tested neutral to + solenoid around 240
Tested neutral to - solenoid very little reading
And 240 between + n - on solenoid
Going to plumb centre tomorrow to get a new solenoid in the how it goes it.
thats what DIYers do, randomly replace parts until it works, by the end of it he will have a 'new' shower
again, you do not have a positive or negative. its also unlikely that plumb centre will have a solenoid either
By positive I mean to live wire going into the solenoid and by negative I mean the return.
I've checked online and found the solenoid I need is in stock at my local plumb centre.
