Energy Dissipated
skystorm
Jun 27, 2009
53
Scotland
Hi all
Here is one, A current of 4.5A flows in a 3.5ohms resister for 5.5 minutes. The energy dissipated is ,
can anyone refesh this old mind of my and show how its done thanks
4.5 x 3.5 x 330 =2,450,12 missed the squared out , if i do it with the square in i get syntax error
You must be pressing wrong sequence on calculator mate. Do 4.5 squared first by doing 4.5 x 4.5 then press equals then do rest of sum. :)
well whaddya know,
never ever seen a calculator returning a syntax error before.!!! :C
you sure you have 2391?
we werent even allowed scientific calculators when I done mine.
well whaddya know,never ever seen a calculator returning a syntax error before.!!! :C
Thats cuz they weren't invented!!!!!!
Slide-rule...
Pencil...
& back-o-the-fag-packet you told Deke????
Hi All,
I will do it the "pen and paper way" or just using the extremely basic calculator on my PC and my not very up to speed brain!!!
Right, so we have a resistor of 3.5 ohms and a current of 4.5 Amps..
So, current times resistance gives voltage, so 3.5 ohms x 4.5 Amps = 15.75 Volts..
Now, Volts times current gives Watts.. So, 15.75 Volts x 4.5 Amps = 70.875 Watts.
Now, this "power", i suppose is the best term, [the 70 odd watts] is flowing for 5.5 minutes.
5.5 minutes is obviously 5.5 x 60 seconds = 330 seconds
A Watt flowing for one second = one Joule...
So if we multiply our 70.875 Watts by 330 seconds, we come up with 23388.75 Joules which is the answer!!
So, energy dissipated... 23388.75 Joules
john..
