Energy Saving Bulbs (lamps)
m4tty
Scaredy cat™
Feb 5, 2009
5,612
I was at a customers house a few days ago and she asked me about a problem with a pendant light by back door and an outside fitting. They were both flickering constantly when switched on. They are both wired to come on together when switched. They both flicker constantly. I took one of the lamps out and the other one came on properly. When replaced they both flickered again. I checked connections in the switch and pendant and all was good and tight. Any suggestions they were phillips lamps so not cheap carp are they?
Cheers:coffee
You may find that one of those energy saving lamps has faulty electronics especially if both of these lamps are quite close to each other on the circuit. Had at least a couple of similar situations on projects....
