matt.leung
just going over an estimate for a new client. trying to work out a labour cost:
here's the job details....
To upgrade consumer unit. The new CU will be a Wylex 10way split load.
To upgrade eco 7 distro unit. This new unit will be a Wylex 5way with a 32a RCBO breaker
To upgrade all of the bonding to water in 10mm. Access will be required to under floor boards in the hall way and in the bathroom.
Location of gas meter is also required
Bedroom:
To convert two single sockets to double sockets. All sockets will be MK
To change the front plate of the FCU.
To install a panel heater.
To change the light switch
To install a new light fitting
Bathroom:
To install a new electric shower. Please note that I will not be connecting up any plumbing. The shower isolator will be located on the outer bathroom hall.
To change the pull cord switch
Bathroom cupboard:
To install a socket for the washing machine.
To install a new timer and isolation switch for the water tank immersion heater
Kitchen:
To convert a single socket to a double socket.
To install a new double socket
To install an isolation switch for a single socket to feed the fridge
To remove a single socket
To remove a double socket
To install an electric oven outlet.
To install an extract fan outlet with isolation
To remove the isolation switch that is located in the kitchen for the water immersion heater.
Lounge:
To change the FCU plate for the storage heater
To convert a single socket into a double socket
To change the socket plates on two double sockets
Hallway:
what do u think is a fair price..
Bedroom:
Bathroom:
Bathroom cupboard:
Kitchen:
Lounge:
Hallway:
