Hi I have been asked to install some Ethernet connection point while doing a house rewire. Want to know do you have to run each connection point back to where the broadband connection is or can i wire the points in series thanks CJS
It will be all back to a central location (assuming 10*BaseT).Hi I have been asked to install some Ethernet connection point while doing a house rewire. Want to know do you have to run each connection point back to where the broadband connection is or can i wire the points in series thanks CJS
I'd agree, although you could use 4 port switches to reduce runs, it's best to have singles all the way back, and in any rooms that might need more the one port, do so, I wish I had when I installed CAT5 though out my house 12 years agoIt will be all back to a central location (assuming 10*BaseT).
Agggrrr. I would never suggest doing that as the utp can not then be used for other services (and raises the possibility of someone creating a loop and a packet storm).I'd agree, although you could use 4 port switches to reduce runs, it's best to have singles all the way back, and in any rooms that might need more the one port, do so, I wish I had when I installed CAT5 though out my house 12 years ago
I need to know what a packet storm is, please?Agggrrr. I would never suggest doing that as the utp can not then be used for other services (and raises the possibility of someone creating a loop and a packet storm).Ian.
Not at all. When you create a loop on a switched network without spanning tree (as these small unmanaged hubs/switches don't tend to do stp), then you end up forwarding the same packet around the network until its TTL expires. That happens with every packet so your network throughput goes down to about .1% if you are lucky depending on the number of hosts on the network.I need to know what a packet storm is, please?Sounds fun
oh dearNot at all. When you create a loop on a switched network without spanning tree (as these small unmanaged hubs/switches don't tend to do stp), then you end up forwarding the same packet around the network until its TTL expires. That happens with every packet so your network throughput goes down to about .1% if you are lucky depending on the number of hosts on the network.Very not nice.
Neither would I use that method (unless I realised 10 years on that more than 1 port per room would handy )Agggrrr. I would never suggest doing that as the utp can not then be used for other services (and raises the possibility of someone creating a loop and a packet storm).Ian.
CAT5e can handle Gigabit, however I'm using Gigabit over 12 year old CAT5 with no obvious problemsyeah thats it, the setups i worked on had a big unit (bit like a three phase 54 way consumer in size). of the pairs from each room coming in one went into the router and the others either went to ipod connections of video streaming setups, its fab what you can do for little money really, dont know if cat5 is been fazed out now abit nowadays in favour of cat6 the its a bit thicker and harder to work with.
Guiness DrinkGuiness DrinkGuiness DrinkCat5 can not. Cat 5e can.
