Existing Mem Elcb
Feb 10, 2009
342
18
I need to make some alterations to circuits within a board that has an MEM 404ELHNC elcb main switch (80A/30mA). These alterations will need RCD protection.
If this device tests out ok - ie 1 x < 200ms, 5 X < 40ms is this acceptable or will I need to fit a new RCD?
Does anyone know the BS number for the MEM device?
Thanks.
I have pulled this out of a 16th Edition, incorporating amendments
1 & 2.
Page 188, BSEN 61008-1  1995.  on RCCB's.
This replaces BS4293;  1983  which, at the time, was
still current.
Hope this helps.
1 & 2.
still current.
Hope this helps.
Yes it does many thanks for that.
So am I correct in thinking that this device is suitable to provide Additional Protection?
Looking at the internet first, I found the standard but
I wanted to tie it up with the current BSEN 61008 one.
It looks like the newer BSEN 61008 superceded the
BS4293 and at the time, it was current.
I stand to be corrected but as I see it, if it does the same
as an RCD or RCBO for additional protection, I cannot
see any problem and could therefore be left in.
Steps got there before me. :Applaud
yes, its fine as long as it passes the trip times.
Thank you gentlemen!
Thats a current operated ELCB (also known as an RCD ;) ), not a voltage operated ELCB.
If your cert has a space for the BS number of the device, then its BS4293 as others say. No reason at all to replace if working fine :)
